BR-VDX6740 - vlan: traffic between access and trunk ports.
‎11-07-2018 03:13 PM
hi guys,
with a client vlan "unaware" and port channel as this one:
Interface name : Port-channel 25
Switchport mode : trunk
Fcoeport enabled : no
Ingress filter : enable
Acceptable frame types : vlan-tagged only
Native Vlan : 4
Active Vlans : 2,4,1310
Inactive Vlans : -
MAC learn disable Vlans : -
and another port channel like:
Interface name : Port-channel 29
Switchport mode : access
Acceptable frame types : vlan-untagged only
Default Vlan : 4
Active Vlans : 4
Inactive Vlans : -
Is "Acceptable frame types" the reason why nodes cannot talk to each other?
How to rectify this problem?
many thanks, L.
Native Vlan : 4
Inactive Vlans : -
Default Vlan : 4
Active Vlans : 4
Inactive Vlans : -
many thanks, L.
7 REPLIES 7
‎11-07-2018 04:06 PM
‎11-07-2018 03:49 PM
Yes,
no switchport trunk tag native-vlan - I though should do (and it seems it does) but weird bit is that this does not change the output of: sh int switch - "Acceptable frame types : vlan-tagged only" remains but!! nodes can ping between.
Weird, no? (I have not tested trunks yet)
‎11-07-2018 03:25 PM
Hi Pawel,
If the host on Po25 is sending packets untagged then I believe the expected behaviour is to drop the packets. You could try making native VLAN untagged on Po25.
Many thanks,
Sargis
Many thanks,
Sargis
