Ridgeline 4.0 installation problem: Problem in Database creation
‎01-08-2014 12:59 AM
Create Date: Jul 9 2013 1:07PM
My problem is very easy to describe:
I can't install Ridgeline 4.0 because it always finish installation with the following message:
Database Creation:
Ridgeline 4.0 installation could not be continued because
Ridgeline 4.0 database creation has failed. Exit code: 0
Host OS: Windows 7 Pro 64b (fresh install)
I tried to install the 32 et 64b version of Ridgeline 4.0: same problem.
EDIT:
I tried to install Ridgeline 4.0 32b on the Windows XP mode (Virtual PC) on the same host:
Installation is working fine !
The problem seem to be only with Windows 7 Pro 62b
Any idea ?...
(from Lauville)
Database Creation:
EDIT:
Any idea ?...
(from Lauville)
12 REPLIES 12
Create Date: Jul 11 2013 8:00AM
Please to know that Ridgeline is working fine with VM under CentOS, but I bought 3 licenses of Ridgeline 4.0 and I MUST install them on Windows 7 Pro 64b (Ridgeline 32 or 64, don't mind..)
I can read in "Ridgeline_4.0_Install_Note.pdf" :
The Ridgeline software can be installed on systems running Windows Vista, XP, Windows 2003 server, Windows 2008 server, or Windows 7 (Ridgeline 32-bit version only) or on systems running Red Hat Enterprise Linux version 5.
But it can't be installed on Windows 7 64b or Windows 2008 R2 !
Does it mean that Ridgeline can only be installed on Windows 7 32b ? Impossible to known !
Quality Control on Extreme Networks softwares seems to be VERY FAUTLY !
BR
Lauville
(from Lauville)
BR
Lauville
(from Lauville)
Create Date: Jul 10 2013 11:52AM
I work several years with Ridgeline 3.1 in a virtual machine with linux CentOS and have tested Ridgeline 4 also in a linux box - it works fine.
If Ridgeline in a virtual linux box you has more flexibility with linux (e.g. cli, tftp, scp) and the virtual envoriment (e.g. snapshot).
Regards,
Elwood (from Peter_Eschholz)
Regards,
Create Date: Jul 10 2013 11:42AM
we have the same problem with a installation on a new windows 2008 R2 server.
Any news or updates??
BR
Rene
(from rene.schmid)
BR
Rene
(from rene.schmid)
