SamPirok
Summary
7720 Universal Switch - ZTP does not work after DHCP times out when using the out-of-band (OOB) management Ethernet port and the pre-installed image 32.4.1.5.
Background
The 7720 switches are currently shipped with a pre-GA software image - Switch Engine version 32.4.1.5. This version of software will not support the Zero Touch Provisioning (ZTP) functionality because of defect ID EXOS-33510. The problem is due to the DHCP request timing out during the DHCP discovery process, resulting in ZTP not being initiated.
Products Affected
7720 Universal switches
Software Affected
EXOS/Switch Engine 32.4.1.5
Symptoms
When starting a 7720 Universal switch using an out-band management (OOB) port and auto-configuration DHCP times out and an Automatic Private IP Address of 169.254.x.x is assigned and ZTP isn’t initiated.
Workaround (solution below)
  • Remove and reinsert the cable to the OOB mgmt port after 10 seconds:
    MGMT Link Front Panel Link Action required after booting up switch (SYS led solid blinking) MGMT DHCP IP XIQ-SE onboarding
    Connected None Physically disconnect and reconnect mgmt link after 10 sec successful successful
    OR
  • Connect an in-band Ethernet port in a manner that results in a port link up:
    Connected Link is up/operational No Action Required successful successful
Solution
Upgrade to EXOS/Switch Engine 32.4.1.10
Please see the full Field Notice here for updates and more details.
