SamPirok
This is an Open Books announcement for new Power Supply Unit (PSU) SKUs applicable for use with 5520, X465 & VSP 4900 series switches. The existing power supply units offered with these switches will continue to be supported.
The new PSUs will initially be generally available in US and EMEA region followed by other countries later. Please refer to the “Schedule” section below for target availability dates in various regions.
The following table shows the new power supply SKUs being introduced. The table also shows the existing supported power supplies on the applicable switches – 5520, X465 and VSP 4900.
Important Notes
1. The following are the minimum software versions that are required on the switch, for use with the new PSUs :
  • EXOS version 31.3.1, EXOS version 30.7.2 for X465 only
  • VOSS version 8.3
2. Previous software versions are not supported with the new PSUs. You must upgrade to the listed minimum software version or later to use the new PSUs with the switch.
3. New and Existing power supply SKUs cannot be used simultaneously on the switch in primary/secondary configuration.
4. The following table lists supported PSU combinations with the new PSUs when dual redundant PSUs are used on the switch.
5. Please refer to the switch datasheet for appropriate PSUs for the switch model.
Ordering Information
Pricing
Schedule
The current schedule is below:
  • Open Books : June 1st 2021
  • Price List Update : June 1st 2021
  • Target GA (US & EMEA) : July 1st 2021
  • Target GA (Specified countries) : Dec 1st 2021
    • Mexico, Russia, Brazil, China, Korea, South Africa, India
Contact Information
For questions regarding Services for the 5420 series described in this announcement please contact:
Terms and Conditions:
  • All terms and conditions of sale shall be governed by the Customer’s (or, where applicable, Channel Partner’s) applicable agreement or Extreme’s Standard Terms and Conditions of Sale and Services in the absence of such a written agreement.
  • Valid and existing contractual discounts, if any, will continue to apply where applicable.
  • This product roadmap represents Extreme Networks current product direction. All product releases will be on a when-and-if available basis. Actual feature development and timing of releases will be at the sole discretion of Extreme Networks. Not all features are supported on all platforms. Presentation of the product roadmap does not create a commitment by Extreme Networks to deliver a specific feature. Contents of this roadmap are subject to change without notice.
