ExtremeCloud Layer 7 not Working ?
info_systemhaus
New Contributor II
I´m building current my first ExtremeCloud Solution in our Demo Lab and wanted to test the "App Filter"
I have created a Network with an own SSID + WPA2 and a own Role. The Role does contain only 2 rules .. "First Rule .. "deny Application Facebook" Second rule .. "let pass all the other traffice" .... but after 10 minutes waiting .. i can surf to Facebook .. and post there without Problem. Has anyone of you already testet this "App Filter" and it worked ??
14 REPLIES 14
Ronald_Dvorak
Honored Contributor
Also check in >Clients, does the client has the right role.
I've changed the role in the network but the client still show the old/default allow role.
Ronald_Dvorak
Honored Contributor
Is the AP synced with the cloud config i.e. mine isn't = * right beside the AP name...
ec16bd659dd64189826dd0629f606261_RackMultipart20170202-118833-1ejrzl5-EZC_AP_sync_inline.png
info_systemhaus
New Contributor II
it don´t work for me .. with this simple stupid config, containing only 2 rules .. the user can Sync his dropbox .. and that should not work .. can anybody explain why ?
854928375cf94b25b633921acf377648_RackMultipart20170202-15805-ztdq2l-Conig_Drop_Block_inline.png
info_systemhaus
New Contributor II
ok .. i will try dropbox and give a reply
Zdeněk_Pala
Dropbox worked for me. I have not tries facebook yer.
Regards Zdeněk Pala
