04-24-2020 11:23 AM
Hi guys.
In my XCA deployment, I do have both centralized and distributed sites with same network/ssid deployment. Filter-id attribute from server is accepted by XCA only for centralized, but not for distributed mode. If I see NAC authorization, everything seems fine. Do you know how can I make Filter-id work also for Wing APs/distributed site? If I change Filter-id to Tunnel-Private-Group-Id as radius attribute, XCA accepts it.
04-24-2020 03:08 PM
Hi Ron,
Thank you for your reply. I already did that testing. It makes the situation worse when I change to standard filter-id. NAC stops sending authorization parameters when I set standard filter-id.
I have been tasting different things on new XCA 04.76.03 version against Wing AP today. I have already found several issues.
BR,
Santosh
04-24-2020 12:09 PM
here the answer from the KB article…..
| Answer |
-Ron
