8.3 Webshell new features
Dan15
Contributor
How is copy paste and logging working in V 8.3? I don't see any menus or options. Any hints?
1 ACCEPTED SOLUTION
Zdeněk_Pala
Logging is disabled by default
Logging is controlled on the Admin page under Diagnostics->advanced->system->web terminal.
There are three controls on the diagnostics->web terminal page. There is a number field that sets the max number of logs. The default is 10,000.
A check box "Enable Logging" toggles whether or not the system will log the web terminal sessions. Web terminal session logs are created in the system log directory under web_terminal_sessions//_.
There is a button that when clicked will remove all log files.
Regards Zdeněk Pala
9 REPLIES 9
Zdeněk_Pala
These controls were working in previous versions also, however not with all browsers. Now it is better in 8.3.
Regards Zdeněk Pala
PeterK
Contributor III
normally, when this is a new feature, it should be documented in the manual.
But this isn't the case. You only found this feature-announcement in release-notes.
I hope this will be corrected in the next document-version.
Rahman_Duran
Contributor II
CTRL+INSERT (for copy) and SHIFT+INSERT (for paste) is working for me from the first versions of web shell. I did not strugled to find them as they are standart on Linux console. But for windows users it should make sense to add a note somewhere on the web shell.
Dan15
Contributor
I found in an older topic that you can perform an insert function with shift-insert. This is all I know so far.
Christian5
I am also interested. Do you have new information Dany?
