EMC 8.3.2.11 - Alam “statistic: PortValidPacketsPercent, value: xx.xx, compared to: yy.yy”
Hello, can anyone help me with this issue, what does it mean, how can I reduce this noise? EMC on 8.3.2.11, we have mainly Avaya ERS BOSS switches.
Hello Community, I've been asked to improve Alarms configuration in XMC at a customer whose network is EXOS-based (currently 22.6). They need their support team to react ASAP in case of any issues, outages etc. related to the network services and co...
Currently running XMC version: 8.4.4.26 EOS S4 version: 08.63.02.0005 Have 4 of the same switches, same model, same version. Two backup fine, two fail, and as far as I can see they are configured exactly the same, SNMP works fine, can login from X...
Inside the Console they are registered with SNMPv3 and they are in green, but in the Access Control part they appear in orange and with an exclamation point in yellow and it gives me the following: Problems Detected (engine cannot connect to manageme...
Hi everyone! I´m facing an issue in XMC that suddenly, services have been turned down. Checking the services, we were able to see that Server is running, but the database is down. After checking some logs, I found this message: “2020-06-17 15:17:...
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
