Some question about EDS Management?
HI all, I am learning EDS Management and i have some question about XMC. Help me to answer them. Many thanks. 1. 2. 3. 4. 5.
Hello, often in the XMC example scripts functions from the module "xmclib" or "device" are used. Is there a documentation what functions are included, what parameters can be send and what returnvalues can be used? If there is no documentation, is t...
Hello anybody, After installing all functions, Switch is not inserted into EMC. After reboot of the Cent-OS host the switch is visible. Where is my error? What can I do? Greeting
Try anybody out there updating NAC appliance via the buildin Inventory Manager Scripts ? What was the experience ? Good - bad ? I have customers with more than 8 or 10 NAC appliances - doing this with Netsight inventory Manager makes it more conven...
Hi,Currently followed this article in configuring management access for ERS switches:https://extremeportal.force.com/ExtrArticleDetail?an=000082104Believe the important step is to make sure the “Passport-Access-Priority” attribute is set. The packet ...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
