Questions and discussions about ExtremeCloud IQ-Site Engine Management Center
Resolved! emc_nbi.query return type
Hello,Why emc_query return type is a java format? It may look you manage it like a dict, but it isn't, it isn't anything like json nor a string that you can convert using json.loads.Trying to iterate sitetree, is way more complex and checks like isin...
Extreme Management Center
Hi. i'm practicing xmc in a lab that i have created.  i have a problem when adding an exos switch to XMC (CLI Login Failed), i configured the snmp profile and cli credentials and i configured snmpv3 on the switch.what is wrong ? did i miss some thing...
Ahmed_101 by • New Contributor III
  • 2213 Views
  • 3 replies
  • 2 kudos
Resolved! XIQ-SE Upgrade Problem
I was trying to upgrade my XIQ-SE to version 24.10.13.5 from 24.10.12.14 and the process stalled on backing up the current installation then the server crashed.  I have tried to restart the server from the VM dashboard but keep getting an "insufficie...
