inventory manager add folder to archives root
Hi all How do I add a folder to the inventory managers archive root?
Using OneView 7.0.5.12 to upgrade the XOS on a X450e-24p switch and it downloads to the switch and installs but the switch never reboots to use the new image. I have "Reset device after upgrade" checked assuming this is the reboot function.
I'm trying to create a Flexview that shows the following OID's: dot11ExtRadioAvgNfCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.31 dot11ExtRadioMaxNfCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.32 dot11ExtRadioAvgChlOccCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.33 dot11ExtRa...
Hi I have been told that Netsight 7 now can do the overheat threshold alarm in Celsius or Farenheit. Where is this set, i can't find it.
Perhaps there is a way to do this, but I couldn't find it. I get several alarms throughout the night about 5 minutes down times that are occurring with my small remote offices that are on cable modems. The ISP seems to do maintenance in the early hou...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
