We have one specific link that USED to be connected to two switches, SWaa and SWab, port 1:2 on both sides. The link was detected in NetSight via LLDP and EDP and showed up just fine on the OneView map. Then a new link was established between the swi...
I have the following problem: 1. Set the SNMPv3 on Extreme switches with siguinetre configuration: snmpv3 add configure user authentication md5 NetSight F4l4b3114c01 privacy F4l4b3114c01netsight_btcol configure SNMPv3 user group add NetSight sec-mod...
CLI XOS to configure the default snmp access for Netsight I would like to add new switches ( X460, X440 ...) with XOS 16.X from the Netsight Console. But it's not so easy to do compare from the legacy Riegeline with snmpv3 ! What are the procedure to...
I made a change in the configuration of SNMPv3 credentials NetSight but I have doubts about this message? Affection services on switches or only in the management of SNMP on NetSight? I appreciate your recommendations
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
