How to export csv file attached in the mail from workflow
I want to export csv file attached in the mail from workflow. I am able to export the textfile but I want to export csv file instead of textfile.
hi teamis it possible to upgrade fabric manager via SSH?thanks in adv.
Hi all,I'm trying to create a workflow in which I would connect to all switches to retrieve ports which are not included in netlogin.My goal is to create a HTML table with all the devices and the ports and send it to myself.But it seems that in the w...
I am trying to use XMC to backup a firewall which has multiple VDOMs "Virtual Domains" configured.To backup this device manually requires that the user first logs onto the firewall then navigates to each VDOM in turn and executes a backup command.It ...
Hi team!!!if you have an old XMC deployed and a fresh installation of XIQ-SE, is there any tool or procedure to export-import config from XMC? Maps, profiles, etc..?Best regardsEF
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
