05-22-2025 07:04 AM
Is it possible to bulk add access point details under Network -> Devices?
I can only add them individually and can't seem to find any csv import option
Thanks
Solved! Go to Solution.
05-23-2025 05:20 AM
hi,
you can use discovery.
you can use XIQ Import APs workflow to import APs from ExtremeCloud IQ = https://github.com/extremenetworks/ExtremeScripting/blob/master/XMC_XIQ-SE/oneview_workflows/README....
You can use Import Devices workflow: https://github.com/extremenetworks/ExtremeScripting/blob/master/XMC_XIQ-SE/oneview_workflows/README....
Good luck
05-23-2025 05:20 AM
hi,
Good luck
