Can not add Extreme Wireless Controller to Netsight
Yakup_Erdol
New Contributor III
Hi all,
We have installed Netsight with version 7.1.3.25 and EWC with version 10.21.04.0005. Netsight can discover switches and NAC appliances using snmpv3 credentials. But we can not add wireless controller using same snmpv3 credentials.
Netsight is not at the same Vlan with Controller or other devices, but they are all reachable. EWC can ping Netsight from data and management IPs.
Thanks.
10 REPLIES 10
Yakup_Erdol
New Contributor III
Here is the screesnhots of the SNMPv3 config of the controller:
3e508c7599cf44ff875a77ec2370711e_RackMultipart20170908-122208-t3g5y3-snmpv3_inline.jpg
Ronald_Dvorak
Honored Contributor
Screenshots of the settings ?!
Yakup_Erdol
New Contributor III
By the way i can not use Console or other Java tools, because they all have the same error: "unable yo launch the application".
I do not you but i am really bored of Java errors, so i gave up to fix them.
Yakup_Erdol
New Contributor III
it works fine using snmpv2.
I have checked the credentials on both sides, and they all match.
when I try to add the controller, the following error occurs:
"Device Discovery 10.x.x.x - SNMP error = No Such Object available on this agent at this OID"
Bharathiraja__S
Hi Yakup,
1) What is the error message ?
2) Are you able to add with other SNMP versions v1 and V2 ?
3) Right click on the device from console and go to MIB tools and share us the screen short.
4) Could you double check the credentials on both ends ?
Thanks,
Suresh.B
