Captive Portal with sponsor approval with XIQ-se & NAC through WIRED network
Sacha_Brys
Contributor
How to setup a captive portal with sponsor approval for guests who authenticate with a connected cable to a switch.
Is there any solution (procedure) for this, I cannot find any workaround ... more specific how would the rule(s) be made up.
Thanks in advance.
2 REPLIES 2
Zdeněk_Pala
The Portal configuration procedure is the same for wired and wireless.
the question is what wired solution you have and what are the redirect capabilities...
- can your switch redirect the HTTP traffic?
- can your switch differentiate packets for unregistered/registered end-systems?
Regards Zdeněk Pala
