Thursday
How to setup a captive portal with sponsor approval for guests who authenticate with a connected cable to a switch.
Is there any solution (procedure) for this, I cannot find any workaround ... more specific how would the rule(s) be made up.
Thanks in advance.
Saturday
Hello,
Please check out the following resources:
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000107795
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000079835
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000082067
Thanks
-Ryan
Thursday
The Portal configuration procedure is the same for wired and wireless.
the question is what wired solution you have and what are the redirect capabilities...
- can your switch redirect the HTTP traffic?
- can your switch differentiate packets for unregistered/registered end-systems?
