Changing Font of Netsight ?
M_Nees
Contributor III
Is it possible to change the font type of classic java tools ?
Sometimes in the past i clould not read snmp passwords clearly (if i unmask them)!
Is it possible to change font type in OneView ?
Regards
1 ACCEPTED SOLUTION
Ronald_Dvorak
Honored Contributor
Just rx my new Samsung 34" widescreen monitor - the best thing if you work with EMC - should come in a bundle with the ADV license šŸ™‚
Wish u all a great weekend,
Ron
6 REPLIES 6
M_Nees
Contributor III
Hello again,
today i check the SNMP PW via OneView - after some searching - i found it!
Administration - Profiles ...
OneView uses a better font that is esasier to read and to differ the charakters ;-))
Additionally you can increase font (Ctlr and +) and you can copy the unmasked PW.
This changes things to better ...
Regards
Stephen_Flahert
Changing the font is not supported for either the thick clients or Oneview.
