Cisco Trunk Interface with Extreme NAC
michael_klaus
New Contributor III
Dear All
I’m trying to enable Extreme NAC for Cisco switches. It works fine for Clients on Access Ports. For Accesspoints (local breakout), I’m trying to get a trunk interface with management vlan untagged and data VLANs tagged.
For XOS Switches, I would create a Role with the needed VLAN Egress config
But I cant enforce this role configuration to Cisco switches
How can I achieve that for Cisco switches with Extreme NAC?
1 ACCEPTED SOLUTION
michael_klaus
New Contributor III
Hi Miguel
Yes sure, I can share my cisco config. In the meantime, I tested NEAT as well and it seems to be easier than using macro.
Macro
conf t
no macro auto global control device
no macro auto global control trigger
macro auto global processing
macro auto execute AP_TRUNK  {
if [[ $LINKUP == YES ]]
then conf t
default interface $INTERFACE
Description AP_TRUNK
macro description $TRIGGER
switchport trunk allowed vlan ##VLAN-LIST##
switchport trunk native vlan ##VLAN##
switchport mode trunk
spanning-tree portfast trunk
macro auto processing
exit
fi
if [[ $LINKUP == NO ]]
then conf t
description NAC
no switchport trunk allowed vlan
no switchport trunk native vlan
switchport mode access
authentication control-direction in
authentication event server dead action authorize
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-host
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
dot1x pae authenticator
dot1x timeout tx-period 10
no macro description $TRIGGER
exit
fi
int range ##INTERFACE-RANGE##
Radius Attribute: Cisco-AVPair=auto-smart-port=AP_TRUNK
NEAT
cisp enable
template AP_TRUNK
switchport trunk encapsulation dot1q
switchport trunk native vlan 100
Radius Attribute: Cisco-AVPair=interface-template-name=AP_TRUNK
Comparison Smart Port vs. Macro:
best regards
Michael
24 REPLIES 24
michael_klaus
New Contributor III
Yes exactly, I use the radius attribute “uto-smart-port=event-trigger” if the mac address is in my Accesspoint End System group.
best regards
Michael
StephanH
Valued Contributor III
Hello Michael,
nice to hear that you have found a solution.
Do you tigger the macro with the radius attribute “auto-smart-port=event-trigger from NAC, if a appropriate device is authenticated on the access port?
Or how do you enable a macro on the specific port?
Best regards
Stephan Harrer
Regards Stephan
michael_klaus
New Contributor III
I solved it with macros because NEATis not available on all switches.
Many thanks for your help.
best regards
Michael
StephanH
Hello Stefan,
I did a quick web search, too. Here is another description regarding NEAT and templates:
https://community.cisco.com/t5/security-documents/ise-secure-wired-access-prescriptive-deployment-gu...
There are some hints in the net about disadvantages concerning the port configuration with NEAT.
for example here: https://community.cisco.com/t5/network-access-control/flexconnect-ap-ise-and-neat/td-p/3302383
It seems that Cisco still has problems to implement a function like "AP Aware" from Extreme.
Best regards
Stephan
Regards Stephan
StephanH
Hello Stefan,
I have searched my knowledge base again.
Maybe a interface template is a good workaround.
https://community.cisco.com/t5/security-documents/neat-with-interface-template/ta-p/3642967
Regards
Stephan
Regards Stephan
