Cisco Trunk Interface with Extreme NAC
michael_klaus
New Contributor III
Dear All
I’m trying to enable Extreme NAC for Cisco switches. It works fine for Clients on Access Ports. For Accesspoints (local breakout), I’m trying to get a trunk interface with management vlan untagged and data VLANs tagged.
For XOS Switches, I would create a Role with the needed VLAN Egress config
But I cant enforce this role configuration to Cisco switches
How can I achieve that for Cisco switches with Extreme NAC?
1 ACCEPTED SOLUTION
michael_klaus
New Contributor III
Hi Miguel
Yes sure, I can share my cisco config. In the meantime, I tested NEAT as well and it seems to be easier than using macro.
Macro
conf t
no macro auto global control device
no macro auto global control trigger
macro auto global processing
macro auto execute AP_TRUNK  {
if [[ $LINKUP == YES ]]
then conf t
default interface $INTERFACE
Description AP_TRUNK
macro description $TRIGGER
switchport trunk allowed vlan ##VLAN-LIST##
switchport trunk native vlan ##VLAN##
switchport mode trunk
spanning-tree portfast trunk
macro auto processing
exit
fi
if [[ $LINKUP == NO ]]
then conf t
description NAC
no switchport trunk allowed vlan
no switchport trunk native vlan
switchport mode access
authentication control-direction in
authentication event server dead action authorize
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-host
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
dot1x pae authenticator
dot1x timeout tx-period 10
no macro description $TRIGGER
exit
fi
int range ##INTERFACE-RANGE##
Radius Attribute: Cisco-AVPair=auto-smart-port=AP_TRUNK
NEAT
cisp enable
template AP_TRUNK
switchport trunk encapsulation dot1q
switchport trunk native vlan 100
Radius Attribute: Cisco-AVPair=interface-template-name=AP_TRUNK
Comparison Smart Port vs. Macro:
best regards
Michael
24 REPLIES 24
michael_klaus
New Contributor III
Hi Stephan
It looks like if you use new-style config mode, changing the authentication host-mode is supported via template
Unfortunately, not all of my switches support new-style, so this is not a way for me to go. So I won’t test it.
Up to now i got it working to send both radius attribute (template and smart-port) to the switch. But the switch does not handle both of them
michael_klaus
New Contributor III
Hi Stephan
Yes you’re right, you can’t change the authentication host-mode via port template. But with Macros it works. What I’m trying to do is to do all the needed config via port template and just the changing the authentication host-mode with a macro. But up to now I didn’t get i working to send both Cisco-AVPair attributes via NAC. I’m still on my engineering.
best regards
Michael
StephanH
Valued Contributor III
Hello Michael,
how did you solve authentication with neat and Extreme APs?
Normal for an standard port (printer, pc,...) “authentication host-mode multi-auth” is a good choice to authentication every client separatly (if more the one is present).
If you now plug an AP to the port “authentication host-mode multi-host” is a better choice to authenticate only the first device (=AP). All wireless clients are authenticated via the wireless controller.
If you use “multi-auth” with an Access Point on the port you will see every wireless client twice. From WLAN and from LAN.
I hoped there is a way to change the “authentication host-mode “ via the port template but it seems that’s not possible.
How do you handle that?
Regards Stephan
michael_klaus
New Contributor III
Hi Miguel
Macro
conf t
then conf t
exit
fi
then conf t
description NAC
mab
exit
fi
NEAT
cisp enable
template AP_TRUNK
best regards
Michael
Miguel-Angel_RO
Michael,
Could you share the solution?
I’m interested in the config lines for Cisco and the definition of the radius attributes.
Thanks
Mig
