If you run Nac Manager (legacy java application) then you can delete them quite easily as all of them will be on the same list.
There is also setting for how long should the inactive endsystem be in the database. You can define when will the endsystem table cleanup happen.
I am sure the setting is also available in OneView.
Regards
Zdeněk Pala
