100 nodes max on map
Does anyone know if there is a way around the 100 max nodes per map?
Hi, I was using "User Device Groups" in XMC to group same location devices. Recently I start to create "Sites" for these locations under /World. When I select several devices, change their "default site" to "World/Arhavi" and press save button it...
Hi, I want to enable port statistics collection on all port.Wen the devices ware add to the XMC the option of enable collection was not selected.Now I want to enable it. the problem is that I have 39.000 ports. Is there a way of doing it massively. I...
Hi,did anyone realized Telenet/SSH access to 3rd party Device “Dell PowerConnect” Switches?As SSH needs double UID/PW (which can´t be confiured in XMC) we moved to Telnet.However, authentication failed. (No matter, in what field the password is enter...
Anyone had an instance where the config in the ‘Site’ in XMC differs from the switch config, because someone has made a change on the CLI level rather than through the site?I want to be able to sync back the config from the switch to the site so that...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
