create a port specific alarm in netsight
jaime_quintana
how i can create a alarm from specific port in switch ?(x450,x670,x460)
17 REPLIES 17
Ronald_Dvorak
Honored Contributor
Let's make sure that your email settings are correct... just click on the "test email action" button in the alarm settings to send a test mail.
0759e0b86fe54d978b331107c74b6ae4_RackMultipart20150723-13465-100hqvn-Netsight_email_test_inline.png
Tavares_Belmont
New Contributor II
@Ron,
I found one filed to create email sender and receiver email and i created the correct alert, however when i tri "disable ports x and enable ports x" the X port are present in the group... I was unable to receiver the email 😞
I must create other configuration before?
i tried:
set mail config put my credentials email and smtp server domain;
action table "edit email list" and add email receivers
enable alarm of course...
other options "select alarm" option Link up
Tavares_Belmont
New Contributor II
Tavares_Belmont
New Contributor II
@Ron,
Bingo! got it...Because i stay connected by VPN and the client use my local ip address, now i tried remote session directory server were the netsight installed and got it, sorry for my mistake.;)
now i gonna create the alarms!
Thanks again!
You'd change that behavior in the Netsight options so all request are done from Netsight and not from your local client.
Netsight Console > Tools > Options > Suite Options > Client Connections > SNMP redirection > Redirect Client/Server SNMP Communications
