custom device-view / flex-view with refresh button?
‎01-19-2023 12:37 AM
I'm using some custom device-views in XMC/XiQ-SE reflecting to flex-views. From github and also self created. eg. current port status or interface-errors.
Is it possible to have a refresh button in such dedicated device-views? Normaly the data read only the first time you open this view. If you want to refresh you need to close the hole device and open again.
‎01-24-2023 05:19 AM
Hello,
Do you see a green "Play" icon in the top right hand corner of the flexview? This should retrieve another set to information from the devices when pushed.:
Thanks
-Ryan
‎01-19-2023 05:22 AM
It's been a while since I set up a custom DeviceView but if memory serves this function is more of a snapshot at the time the DeviceView is opened than live. While some functions built into DeviceView have a refresh button - most do not. I suppose a feature to 'Refresh' the DeviceView vs close and reload might be doable but this would have to be discussed with your @extreme account team.
I don't think there's a function to add a 'refresh' button to custom views, like the ones you are able to grab from GitHub.
