Difference between trap and syslog message?
Visconti
New Contributor III
do anyone explain to me what is the difference between trap and syslog message?
17 REPLIES 17
You'd receive the trap and/or the syslog message from the device that is able to generate SNMP traps and/or syslog messages.
The message inlcudes the IP from the sender.
Erik_Auerswald
Contributor II
a trap is an SNMP message, sent via SNMP protocol using UDP destination port 162 (by default). A Syslog message is message sent via Syslog protocoll using UDP desitnation port 514 (by default).
SNMP was developed for network management, Syslog was developed for Unix-like systems.
While Syslog uses text messages that are supposed to be easily read by humans, SNMP traps use structured binary data that needs to be translated to human readable form based on a formal definition (MIB).
That said, both are used for the purpose of sending information regarding some kind of event to a central server.
Thanks,
Erik
