Hi, my customer contacted me as renaming VLANs with EMC isn't working.
I've tried it with my EMC 7.0.4.29 and a D2 v06.03.15.0002 and see the same problem.
As I'm able to enable/disable ports on the D2 with EMC I'd say my SNMP settings are OK.
The txt file from the script log....
root@ControlCenter.labvienna.at:/usr/local/Extreme_Networks/NetSight/appdata/scripting/tmp/root$ cat 3_172_24_24_150_20160825-013501.txt
User: root
172.24.24.150 172.24.24.150 2016-08-25 at 13:35:01 CEST
*** Error at line - 881 ***
This script is only supported for Extreme switches.
Is the rename function for VLAN really only supported/working for XOS ?
Where could I find the EMC restrictions - is there some document available.
Thx,
Ron
