Hi all.
I'm facing the same "issue": I'm on version 8.0.3.53 and I'd like to be able to export in some useable file format (csv, txt, xls, or simiilar) the end-systems list (after applying a filter).
I tried with the "axis/services/NACWebService/getAllEndSystem" path but it did not work. I get following error displayed:
"The endpoint reference (EPR) for the Operation not found is /axis/services/NACWebService/getAllEndSystem and the WSA Action = null"
Any help will be much appreciated!
Thanks,
Flavio.
