Exporting NAC End System Data
Andre_Brits_Kan
Contributor II
How do I go about exporting the end system information from NAC Manager to excel?
In oneview I can export to a PDF but I would like to export all the data to Excel.
Thx
Andre
14 REPLIES 14
StephanH
Valued Contributor III
Hello,
in the near future we won't have the lovely Java NAC-Manger for the scheduled export like this:
116dc957ee2849269fef95c729c5d9ae_RackMultipart20170317-50818-he3x6r-NAC_Export_inline.jpg
Therefore the question is. How can I export the data in the same way via Extreme Control Center?
The way Thomas showed above delivers to less informations. Many of my customers need all Infos from the table and not only a small part of this.
Are there any new ways?
I know I can do it via Webservices. But this is not very handy.
Regards
Stephan
Regards Stephan
Mike_Thomas
You are also able to export these via oneview, but only via a Custom Report Tab.
It will not be as detailed as mp2014 method however.
mp2014
New Contributor II
in NAC Manager End Systems View:
click the wrench and Table Tools --> Export --> delimeted Text. Save an CSV that will open just fine in excel.
Andre_Brits_Kan
Contributor II
Hi Mike
V6.3.0.168
Thx
Mike_Thomas
Hi Andre,
which version of software are you using?
