ExtremeAnalytics Virtual Sensor OVA
amoriconi
I couldn't find the link to download the virtual sensor OVA appliance for ExtremeAnalytics version 23.7.11.6
The links found with the search take you back to documentation still hosted by the emc.extemenetworks.com website
Is it possible to download this file from the extreme portal?
Thank you
2 REPLIES 2
Zdeněk_Pala
Hi Amoriconi.
There is very often some confusion in the naming of Analytics components.
  1. Application Analytics Engine (formerly called Purview) is available at Extreme Portal - as mentioned by Ryan Yacobucci.
  2. Traffic Sensor (formerly called NG Analytics Engine) is available only as a HW
  3. Virtual Sensor (EA Virtual Sensor VS100, EA Virtual Sensor VS250) is end-of-sales and end-of-software-maintenance and does not have any new version.
Hope it helps
Regards Zdeněk Pala
Ryan_Yacobucci
