‎10-16-2020 01:48 PM
How do i upgrade ers3650 with extreme mangement center
some many ers3650 6.2.015 to 6.4.1.007
In EMC > configuration/firmeware/>upgrade firmware > assign image ? format new image
I have 3600_6100_diags.bin and 3600_641007s.img
Thanks explain to me the procedure with emc
Solved! Go to Solution.
‎10-17-2020 06:18 PM
Hello,
Please check out the following article on how to upgrade using XMC:
Make sure you download and transfer the desired firmware and assign it the correct device type when uploaded.
Thanks
-Ryan
Hello,
Thanks
-Ryan
