how to add port groups to Eaps Domain in Netsight ?
Tiburcio_Jr_Cor
New Contributor II
In Ridgeline you would create port groups and associate those port groups to a defined Eaps Domain and run a script to add a new vlan to those ports. How would you perform this in Netsight 6.3 ?
18 REPLIES 18
Thank you for the information. Are ports 1:6 and 2:6 already members of vlan 'burke_commerce'? If they are not, they need to be added to the vlan. If you have not already done so, these same ports need to be added to the EAPS control vlan too.
b204a3638255457b8abd818263fedf72_RackMultipart20160203-92828-1xwnj3t-Eaps_Burke_Script_Netsight_inline.jpg
My script on NetSight
#@MetaDataStart
# Define your user parameters in this section. For reference, see EPICenter bundled scripts.
#@VariableFieldLabel (description = "VLAN Name",
# type = String,
# scope = global,
# required = yes
set var vlanname ""
#@VariableFieldLabel (description = "VLAN Tag", type = String,
# scope = global,
# required = yes
set var vlannametag ""
#@MetaDataEnd
# Enter all CLI commands from here
create vlan $vlanname
config vlan $vlanname tag $vlannametag
disable igmp snooping vlan $vlanname
config eaps burke_commerce add protected $vlanname
config $vlanname add port $port tagged
regexp {.*Adding EAPS ring ports to a VLAN could cause a loop.*} ${CLI.OUT} foundit
IF ([info exists foundit]) THEN
CLI y
ENDIF
You can upload an image to a post using the icon that looks like a camera when typing your post.
Were there any messages in the switch log indicating a problem as the script ran? If there are some, please post the output of those messages too.
a total of 3 switches and 6 ports
