Resolved! Get port descriptions via RESTAPI from XIQ-SE device view
Hello everybody,is there a way to read out all port numbers & port descriptions (display-strings) from a specific switch in XIQ-SE via RESTAPI?Thanks & best regards,Kevin
Hi, In my network I have an Enterasys WC-25 controller with many Enterasys WS-AP3705i access point. Now I have to upgrade the system and I have find out the model in the title. Can I be sure that the controller can correctly rules the APs or can I ha...
ExtremeCloud IQ – Site Engine 23.7.10.85 is now live on Extreme Portal, and available to our customers and partners.There are the following major features in this release:XIQ integration:Synchronize Sites with ExtremeCloud IQ Locations.New top menu i...
In the analitycss dashboard there is no info about networks and application response.I have checked the config on the switches:ACL: okconfigure access-list telemetry any ingressconfigure access-list telemetryegress any egressETMON: okconfigure sflow ...
Hi,Do you know if a nbi mutation for disable/enable or reset inline-power for a port exist ?I found nothing about itRegards
| User | Count |
| 102 | |
| 101 | |
| 42 | |
| 19 | |
| 17 |
