How to backup Enterasys S4 S-Series with netsight Inventory Manager
Alexandre_Lima
I already configure the Inventory Manager to make backup of the switch S4, but the inventory manager show follow error "Device reported, operation failed". How can I handle this issue?
Netsight 6.1.0.171
Core Switch S4
8 REPLIES 8
Alexandre_Lima
Hello,
Thank you, guys for your help, but I no longer give support to this applaince and solution. I can't test that commands and I couldn't find the solution for this issue.
Thank you, again.
Ryan_Yacobucci
Hello,
Have you been able to successfully backup the S series?
Thanks
-Ryan
Bastian_Sprotte
6.1 should be able to build an inventory from S-Series,
-you should check at first if the S-Series get all instruction from NMS.
on the S-Series cli you see such event if you make an Inventory / Stamp New Version ,,
set logging here enable
set logging default severity 7
set logging application Security level 7
<166>Sep 30 09:25:45 10.131.213.254 Security[1]User:public; Source:10.131.213.12; Action:"etsysConfigMgmtChangeRowStatus.1 = 5"; Status:OK
<166>Sep 30 09:25:45 10.131.213.254 Security[1]User:public; Source:10.131.213.12; Action:"etsysConfigMgmtChangeOperation.1 = 04:00"; Status:OK
<166>Sep 30 09:25:45 10.131.213.254 Security[1]User:public; Source:10.131.213.12; Action:"etsysConfigMgmtChangeURL.1 = tftp://10.131.213.12/configs/tmp/10_131_213_254.cfg"; Status:OK
<166>Sep 30 09:25:45 10.131.213.254 Security[1]User:public; Source:10.131.213.12; Action:"etsysConfigMgmtChangeDelayTime.1 = 0"; Status:OK
<166>Sep 30 09:25:45 10.131.213.254 Security[1]User:public; Source:10.131.213.12; Action:"etsysConfigMgmtChangeRowStatus.1 = 1"; Status:OK
<166>Sep 30 09:26:05 10.131.213.254 Security[1]User:public; Source:10.131.213.12; Action:"etsysConfigMgmtChangeRowStatus.1 = 6"; Status:OK
If you see this event, good,
now the TFTP server needs to be checked,
regards
Bastian
Alexandre_Lima
The management interface is already configured. I think that the cause of the problem is because the NetSight is in the version 6.1.0.171. How can i make backup and upgrade to version 6.3.0.182? Ara there some configuration to do before the installation?
