Resolved! Add file to mail on a workflow
Hi,How can I add a file to mail in a workflow. Regards,JChaves
I have been successfully archiving a cisco 2811 router for years. I have installed a new ISR4351 this year as a replacement, but so far my archive script has been failing.I know that EMC can authenticate properly to the 4351, as I can use terminal f...
Hello, I want helpdesk user staff only to view devices on a define zone on Extreme Management Center. I could successfully set the zone to the devices via extreme control rules but I can't see any field or place where to set the zone to the authoriza...
Is it possible to change the font type of classic java tools ? Sometimes in the past i clould not read snmp passwords clearly (if i unmask them)! Is it possible to change font type in OneView ? Regards
we have a lot of G1 and G2 mix of switches. Looking for a way to generate a report about the authentication status of EXOS G1 switch ports, whether they are enabled for netlogin mac, 802.1x or open port, need the report per switch. Possibly using X...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
