How to bind a Custom FlexView in to Oneview Device View
‎06-08-2015 01:56 PM
I created my custom FlexView, now I would like to apply this flexview to a specific device,
so I can see the information about these flex on the Device View of the OneView.
How I can set up this binding?
Thanks
Roberto
Thanks
Roberto
		20 REPLIES 20
‎02-12-2019 10:13 PM
						I published the flexview for you at GitHub.
enjoy and share and let me know the feedback!
Be EXTREME!
Be EXTREME!
	Regards
Zdeněk Pala
‎07-16-2018 02:36 PM
						Hi.
I just found this conversation. If you want to bind FlexView with DeviceView, you can get inspiration here: https://github.com/extremenetworks/Netsight-Report-Views/blob/master/DeviceView/README.md
You can have more FlexViews in the same DeviceView also...
	Regards
Zdeněk Pala
‎02-11-2019 11:50 AM
						Good morning,
I would like to participate in this discussion..
I need to view the column "Port Alias" in the flex view "LEARNED MAC ADDRESES"
SO I have duplicate the .tpl file and I try to manage the new flexview
but I can only show the column isAlias but this column is not populate
I'm going crazy
can someone help me?
I'm going crazy
‎10-08-2015 11:52 AM
						This may take some modification of MyDeviceFamilyMenu.xml file to work properly with third party gear.
I would open a ticket with the GTAC and we can look if there is a way to solve this problem.
‎09-30-2015 06:58 PM
						I am experiencing a similar issue. My custom flex few columns  display but the data fields do not populate.
Does OneView require the mibs to be in a different folder than Console does?
