Hello Visconti,
unfortunately, there is no general export function like in the java console (legacy tool).
You can export reports by sending via the scheduler (XMC->Tasks->Scheduled Tasks->Add).
In some views (not in the alarm panel) you see an Excel symbol in the corner. If you click there an export windows opens.
In my opinion here is a ToDo for the extreme people to create an export option on all table panels like in the legacy tool.
Best regards
Stephan
Regards
Stephan
