Config Archive for Arista Devices
Dear all. we want to archive the device configuration of our Arista Switches with XMC. Does anyone have experience if this is possible? thanks and best regards Alex
Hi team, I´m deploying a new XMC in last release 8.2.4.55, and in the first login, previous to configutarion wizard, I´m unable to login. In the "Extreme Management Center®NMS-A-25 Installation Guide" says that credentials are root with no passwor...
Can xMC off load syslog to another syslog server? If so please show me how. Thank you
Hi all The Analytics browser does not resolve IP to names, although they are available via DNS. Hostname lookup is globally enabled under "Name resolution". DNS on OS level is configured for XMC and Analytics. Any ideas?
Hi I see that XMC is doing logins to all VSPs each 15 minutes. Is there a reason for that or better is there a way to stop that? I disabled all options under "Management Center Collector" that had 15 minutes interval to find the cause, but no succes...
| User | Count |
| 94 | |
| 93 | |
| 41 | |
| 19 | |
| 17 |
