How to use Netsight to backup Extreme switch configurations?
‎07-21-2016 05:35 PM
Am using Netsight to backup the Extreme switch configuration. I have 100 switches in my network. Kindly help me with the steps to backup from netsight.
10 REPLIES 10
‎07-22-2016 10:03 AM
Could you please provide a screenshot of the following two windows.
- in Inventory manager select one of the X-switches - I'd like to see the info in the right "general" tab
- then select the "image information" tab and post that also
- Netsight version
- is 10.102.9.102 the IP of the Netsight server
- Netsight version
‎07-22-2016 09:54 AM
I am getting error as " Configuration file is empty". In all the switch am using VR-Mgmt.
Even when i use the below manual script in all the switch it is working.
"tftp put 10.102.9.102 vr "VR-Mgmt" primary.cfg 10_102_9_248_primary.cfg"
In this below script let me know which one i have to edit:
VR_VAR.Default=VR-Mgmt
PUT_FILE_CMD.Default=tftp %TFTP_IP% -v "%VR_VAR%" -p -l %LOCAL_FILE_NAME% -r %REMOTE_FILE_NAME%
GET_FILE_CMD.Default=tftp %TFTP_IP% -v "%VR_VAR%" -g -l %LOCAL_FILE_NAME% -r %REMOTE_FILE_NAME%
RESTORE_PRIMARY_CMD.Default=tftp get %TFTP_IP% vr "%VR_VAR%" %RELATIVE_TARGET_FILE_PATH% primary.cfg force-overwrite
Kindly help in this script please
‎07-21-2016 05:55 PM
I have did all that but am getting this error in all my devides
Can you please help me to resolve from this.
Thanks Drew.
Let me try this today.
Here is an article that may help understand this error: EXOS Switches fail to archive with Inventory Manager
There's also another topic that covers this:
https://community.extremenetworks.com/extreme/topics/can-i-specify-the-vr-netsight-uses-to-pull-back...
