‎12-19-2018 08:47 PM
Under Policy then VLANs, there is the "Global VLANs" section and I was wondering if there is a way to add new VLANs or if we can only modify the currently created ones with our VLAN names/tags?
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎12-19-2018 08:58 PM
You can create new vlans by right clicking on Global Vlans and create vlan.
2 REPLIES 2
‎12-19-2018 09:15 PM
Thanks. I get so used to looking for the "Add" button that I forget to right click.
