Is it possible to re-set the Extreme Management / OneView Wireless Dashboard?
Christopher_Tay
Contributor
I changed one of the report boxes in "Report Designer - Wireless Overview" and it through everything out of whack. Is there a way to re-set the Wireless Overview / Wireless Dashboard report back to default or can someone list the default reports that make up the dashboard so I can put them back in manually.
6 REPLIES 6
Ryan_Yacobucci
Also,
You may be able to get a browser plugin that does a timed refresh, so you could refresh every 15 minutes using a plug to get a more live feeling.
I think mozilla has one and there's another conversation around here somewhere, but I can't seem to find it.
Thanks
-Ryan
Ryan_Yacobucci
Unfortunately no.
The "Events" pane has an auto refresh option. Also remember that information bye default is collected every 15 minutes, so even if you had an auto refresh every 15-30 seconds the reports wouldn't change until the collector ran it's poll, which is a 15 minute default interval.
Thanks
-Ryan
Christopher_Tay
Contributor
By "more Live" I mean having the information auto refresh at 15 or 30 second intervals
Ryan_Yacobucci
What do you mean by more "live"?
Thanks
-Ryan
