Is it possible to re-set the Extreme Management / OneView Wireless Dashboard?
Christopher_Tay
Contributor
I changed one of the report boxes in "Report Designer - Wireless Overview" and it through everything out of whack. Is there a way to re-set the Wireless Overview / Wireless Dashboard report back to default or can someone list the default reports that make up the dashboard so I can put them back in manually.
6 REPLIES 6
Christopher_Tay
Contributor
Thanks Ryan worked great. Is there anyway to make the dashboard more "live" ?
Ryan_Yacobucci
Hello,
You should be able to replace the WmDashboard.xml with this file:
https://extremenetworks2com-my.sharepoint.com/personal/ryacobuc_extremenetworks_com/_layouts/15/gues...
Download that file and replace the /NetSight/appdata/OneView/Reports/WmDashboard.xml with it.
You may also want to delete the NetSight/Appdata/OneView/MyReports/WmDashboard.xml too.
Thanks
-Ryan
