Is there a way to start a scheduled task more often than every hour?
‎10-28-2018 08:17 PM
Hello,
Is there a way to start a scheduled task more often than every hour in XMC?
If have to start it every five minutes for example.
If necessary to edit some hidden files, that is not a problem for me 😉.
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
5 REPLIES 5
‎11-01-2018 07:53 PM
Hello Matthias,
thenk you for your tips. I already know both and I have already tried to solve my problem with it. I also found the table where the time is stored (ns_qrtz_cron_triggers).
However, there are several dependencies on other tables regarding start and end times as well as the value "next run" from the Scheduled Task. Therefore, it is difficult to see whether manual changes are needed and do not break anything.
Thus, the idea of ​​Ron is easier implement.
There is already a FR 0170550 with the desire to change the behavior via the GUI.
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
‎11-01-2018 04:42 PM
Hi Stephan,
do you know this:
do you know this:
‎11-01-2018 04:20 PM
Hi Stephan,
all tasks are saved in XMCs local mysql database.
With necessary SQL knowledge you can multiply the needed tasks as you need.
Unfortunately i never try.
Regards
Regards
‎10-29-2018 09:17 PM
Hey Ron,
that's a good idea. It's a nasty workaround but much better than nothing and it works.
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
