How do i modify Referenced Firmware in XMC 8.1.4.40
‎10-31-2018 02:47 PM
After upgrading to this version 8.1.4.40 we noticed this new widget for Referenced Firmware, however it must be referencing a newer version of XOS than we are currently using. How do I modify this to reflect the version we are currently using?
4 REPLIES 4
‎11-01-2018 10:11 AM
Hello,
can you try in the Archives to stamp a new version, Networks/Archives/-Right click- on the archive your device is in. Let see if that change it.
regards
Bastian
regards
Bastian
New archive version did not give the solution. same information in the dashboard
Johan Hendrik
System Architect
Audax
‎11-01-2018 09:57 AM
I have the same problem.
I did as descripted but with no luck.. I can assign the new firmware as reference firmware but in the dashboard is now information
Johan Hendrik
System Architect
Audax
‎10-31-2018 03:49 PM
Hello,
on the OneView- Networks/Firmware TAB you see the Firmware files per device.
Click on the Summit Series Folder, now you should see the *.xos files you have on the server.
Right click on the xos version you use, allow you to define the "Set as Reference Image" this now will define on the Dashboard if that match with the used Firmware that you are fine.
regards
Bastian
regards
Bastian
