Laptops unable to connect to wireless
Kent_Sapp
Our school district's Windows 7 laptops are unable to connect to the wireless with the "validate server certificate" setting enabled under the wireless properties. If I uncheck that box the laptop is able to connect. With about 1000 laptops unchecking that on all will be a pain. Would adding a certificate to the NAC solve this problem?
8 REPLIES 8
Kent_Sapp
Just an update. We got a certificate from GoDaddy and added the wireless settings to a gpo. Our laptops are now connecting without issue. Thank you for all your advice.
Drew_C
Valued Contributor III
Hi Kent, Thanks for coming back and updating the thread. Glad to see you got it sorted out!
Kent_Sapp
Is there a was to export the current certificate in NAC so I can deploy it on a laptop?
Where is your root CA, if NAC is terminating 802.1X the certificate will be self signed and probably not what you want?
This article might help: https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Update-NAC-Internal-Communications-...
