ldap
‎06-11-2015 08:10 AM
Connection problem with Open LDAP server
E.q I have to connect to some LDAP server, and, i decide to connect to some external LDAP server
This one
Server works, but, it's anonymous accessible, and it's open Ldap
However, after 2 days im still getting LDAP: error code 34 - invalid DN
All types of management software connect to them without any problem...
And, as i understand NAC support only Simple Authentication with LDAP, what if i have some GSS connection?
This one
2 REPLIES 2
‎06-15-2015 06:02 PM
OK, thanks, case closed
‎06-11-2015 12:40 PM
Hello,
From what I understand you're having issues connecting to the ldap.forumsys.com test open ldap server from the link you provided.
I have successfully connected to this open ldap server without an error code.
The search roots may not be correct, but I was able to successfully connect to the server.
Does this help?
Thanks
-Ryan
Does this help?
Thanks
-Ryan
