NAC Automation
‎10-21-2020 05:59 AM
Hello
I’m on a NAC Project with about 400-500 NAC Rules. To configure all of them manually it’s a real pain. What possibilities of automation are available?
Following tasks I’d like to automate:
- vlan creation
- Create NAC Rules
- Create NAC Profile and assigns accespt Policy
For the following Tasks I found a solution for automation:
- location Groups => can be done via CSV import
- End System Groups => can be done via CSV import
- Policy Mapping => Can be imported from CSV via legacy
Unfortunately, the API does not support a lot of configuration Tasks. Does anyone have an idea if there is another way to automate this steps?
best regards
Michael
1 REPLY 1
‎10-21-2020 07:42 AM
Michael,
The only option available is createGroupRuleProfilePolicy but is is quite limited in flexibility.
Here the code from XMC_NBI:
def createGroupRuleProfilePolicy(self, group_name: str, vlanId: int, vlanName: str, cfgDomain: str = 'Default'):
'''create NAC group, rule, profile, policy'''
query = '''
mutation {
accessControl {
createDCMVirtualAndPhysicalNetwork(input: {
vlanName: "<VLAN-NAME>"
primaryVlanId: <VLAN-ID>
nacConfig: "<CONFIG-DOMAIN>"
status
message
Mig
