Python version on XMC
Hello, what version of python is used in the XMC scripting engine? As I see both versions (Python2 and Python3) are available on XMC ubuntu. Best regards Stephan
After configuring EWC to send data to PurView Analiticys an strange problem happend. The data that the AP send to Purview was detected by our wan router and send the to opur intenal firewall. For the firewall thsi is spoofing because the networks ...
Received a new whiz-bang desktop machine and installed Netsight Console Java app on it. However, when I run the Discover tool, it will not discover any devices using the profile, Poll type set to 'Ping'. Seems it will only discover devices that have ...
For some reason OneView will not collect data about Network and Application performance. When I look at the impact analsys and put the mouse on that field I see the message: This data is unavailable or unlicensed. How to solve this ?
I have an X450G2 24 port test switch and I wanted to see if XMC (Netsight) could push the newer SummitX-22.5.1.7.xos firmware file to it. The firmware is loaded and I attempted to have this pushed to the switch. After about 8 minutes or so of no pr...
| User | Count |
| 101 | |
| 100 | |
| 42 | |
| 19 | |
| 17 |
