ā07-20-2023 06:25 AM
Do you know if a nbi mutation for disable/enable or reset inline-power for a port exist ?
I found nothing about it
Regards
ā07-21-2023 05:52 AM
I“d try defining a port template with poe enable and another with poe disabled and apply them here:
mutation>networkmutations>configuredevice>deviceconfig>deviceconfiginput>portconfig>deviceportsconfiginput>portconfigs>portconfiginput>portemplatename
ā07-21-2023 05:25 AM
There does not appear to be. Using XMC/XIQ-SE I imagine this could be accomplished via scripting doing CLI commands or a mass Execute CLI command.
ā07-21-2023 05:29 AM - edited ā07-21-2023 05:30 AM
NBI call can start workflow. The workflow can use CLI commands or SNMP.
As Robert mentioned there is no NBI call to manipulate PoE directly.
Sincerely yours
