07-19-2023 01:07 AM
In the analitycss dashboard there is no info about networks and application response.
I have checked the config on the switches:
ACL: ok
configure access-list telemetry any ingress
configure access-list telemetryegress any egress
ETMON: ok
configure sflow sample-rate 1024
configure sflow poll-interval 60
enable sflow
configure sflow collector 10.2.x.y port 6343 vr "VR-Default"
configure sflow agent ipaddress 10.2.x.z
configure sflow ports 1 sample-rate 1024
enable sflow ports 1 ingress
Mirror EAN ok
create mirror "EAN"
configure mirror EAN to remote-ip 10.2.x.y from 10.2.x.z ping-check off
enable mirror EAN
What can be wrong?
07-23-2023 11:09 PM
All setting checked.
I've configured a new appliance and have now network response. Applicantion still no data.
Any idea?
07-21-2023 07:56 AM
Have you configured the endpoint locations to include your local networks?
07-21-2023 03:43 AM
** Extreme Analytics Version 23.4.12.3 **
process status restarts pid start time
appid started 0 7641 Fri Jul 21 11:53:05 2023
appidserver started 0 7699 Fri Jul 21 11:53:05 2023
To my knowledge the interfaces are in the correct mode. One interface for management en monitoring.
07-21-2023 05:34 AM
if you see values in the flow tab then the underlying infrastructure should be fine (ports, switches).
check the Analytics > Configuration > Configuration > Dynamic Thresholding
