Hello,
We use Extremen Mangement Center (Netsight) for nearly all customer situations and enjoy the multi-vendor solution. But one customer is very frustrated by the small impact he gets in his Cisco environment.
The installed version of Netsight is 7.1.1.9, but I test the features parallel in my lab with the Netsight version 8.1.1.41. Used Switches are e.g. Cisco 2960 or 3650.
I miss alot of informations in the Device View of the Switches:
-VLANs on all ports
-port information (trunk port, access port, ...)
-possibilty to change vlan setup for each port
-serial number of all members in a stack
Other threads in the forum showed workarounds with FlexView. There I could get more information, but this is not user-friendly scenario to search information in several different views. Configuration changes are also still missed in FlexView.
When it is possible to get the information in FlexView, the informations are already existing in the netsight database and they are not shown in the device view. Are there changes in the MIB possible to solve this problem? What possibilities exist for improvements of MIBs in behavior of the integration of third-party products?
Thank you very much.
